Potential Change in a Circuit Diagram
1 reply · 4K views
daimoku
[SOLVED] Potential Change in a Circuit Diagram
http://personalpages.tds.net/~locowise/test/28_29.gif
If the potential at point P is 400 V, what is the potential at point Q?
Ohm's Law: deltaV=iR
Probably the fact that the sum of changes in potential in a loop of any circuit must be zero.
Not real sure on this problem. I tried this:
150V - 2.0i - 3.0i - 50V = 0V and found i to be 20A.
I'm kind of puzzled and can't seem to relate the material in the textbook to this problem. Where does the 400V potential come into play? Thanks for your help!
I'm still not really sure this is the proper way to approach the problem but apparently the solution is correct. Here's what I did:
Used 20A from above.
400V - 50V - 3.0ohms * 20A = 290V
