Potential Difference: 1 J = ? V
To determine the potential difference when 1.0 joule of work moves 1.0 coulomb of charge, the formula for potential difference (V) is used, which is V = work/charge. This results in a potential difference of 1.0 volt. The discussion confirms that the correct answer is option 1, which is 1.0 x 10^0 V. Participants clarify that potential difference equates to the energy per unit charge. The conclusion is that the potential difference is indeed 1.0 volt.
zelda1850
if 1.0 joule of work is required to move 1.0 coulomb of charge between two point in an eletric field the potential difference between the two point is
1) 1 .0 x 10 exponenet 0 v
2) 9.0 x 10 exponenet 9 v
3) 6.3 x 10 exponenet 18 v
4) 1.6 x 10 expeonent -19 v
i think there is an equation for it does anyone know?
not sure need equation
Hi zelda1850! :smile:
(try using the X2 tag just above the Reply box :wink:)
Potential difference = potential energy per charge, and work is a form of energy. :wink:
oh so potienal difference is 1.0 too then?
Looks like it! :smile:
