Pressure of Helium inside a balloon floating in air
The discussion centers on calculating the absolute pressure of helium inside a spherical balloon with a radius of 2.98 m and a mass of 3.16 kg, filled at a temperature of 285 K. The surrounding air density is 1.19 kg/m³. The buoyant force is calculated using the formula F = (mass object)(g) = (ρliquid)(Vobject)(g), leading to a total mass of 131.912 kg for the balloon and helium combined. The final pressure calculation using the ideal gas law results in P = 6.88 x 10^5 Pascals, although the original poster's answer was marked incorrect, suggesting a potential error in the final calculation.
  • Understanding of buoyancy principles and the buoyant force equation
  • Familiarity with the ideal gas law (PV = nRT)
  • Knowledge of spherical volume calculations (Volume of a sphere = (4/3)π(r^3))
  • Basic concepts of moles and molar mass calculations
  • Verify calculations involving buoyant force and mass of helium
  • Explore the implications of negligible buoyancy in balloon physics
  • Learn about the ideal gas law applications in real-world scenarios
  • Investigate common errors in pressure calculations for gases
Students studying physics, particularly those focusing on fluid mechanics and gas laws, as well as educators seeking to clarify concepts related to buoyancy and pressure in gases.
yaylee
Pressure of Helium inside a balloon "floating" in air
A spherical balloon of radius R = 2.98 m is made from a material of mass M = 3.16 kg and is filled with helium gas at temperature T = 285 K. Assume the thickness of the balloon is negligible compared to the radius of the balloon, and the balloon just floats on air, neither rising nor falling. If the density of the surrounding air is ρ = 1.19 kg/m3, find P, the absolute pressure of the helium inside the balloon.
ASSUME: The balloon material displaces a negligible amount of air, and therefore creates no measurable buoyancy.
Buoyant force of an object "floating": F = (mass object)(g) = (ρliquid)(Vobject)(g), and the "g's" cancel.
PV = nRT
moles = grams/ (grams/mol)
First: find the mass of the TOTAL object. We can then subtract the mass of the balloon's material from the Total mass to find the mass of the Helium itself.
Use, Buoyant Force equation, where (ρliquid)(Vobject) = (mass object) = (1.19)(4/3)π(2.98^3) = 131.912 kg.
Then: (mass object) - (mass of balloon material) = mass of Helium = 131.912 - 3.16 = 128.75 kg = 128,750 grams.
number of moles of Helium inside balloon: 128, 750 g/4 g/mol = 32187.50 moles.
Now: can use pv = nRT, or P = nRT/V = 32187.50(8.314)(285)/((4/3)(∏)(2.98^3) = 6.88 x 10^5 Pascals.
The answer key marked me incorrect, however, I believe I have reasoned the problem correctly. Does anyone have any suggestions?
My unlimited thanks in advance!
I think you're an order of magnitude out. Check the final calculation.
Thanks!
12K
