Projectile motion of plate fall
The discussion revolves around calculating the projectile motion of a plate falling from a counter. The plate slides off horizontally at a speed of 0.84 m/s from a height of 1.34 m. The time taken for the plate to fall is determined to be approximately 0.52 seconds, with the horizontal velocity remaining constant at 0.84 m/s. The vertical velocity just before impact is calculated to be around 5.12 m/s. Participants emphasize using the horizontal speed and time to find the horizontal distance traveled before hitting the ground.
helpsara20
projectile motion (URGENT!)
A busy waitress slides a plate of apples along a counter to a hungry customer sitting near the end of the counter. The customer is not paying attention, and the plate falls to the ground horizontally at .84m/s. The counter is 1.34m high.
Find time it took for plate to fall.
Find how far it fell from the counter (delta x)
find horizontal and vertical components of velocity before it hits the ground
there are many.
i found time which i think is .52s
and since vx is constant the horizontal component is .84
and i believe the vertical is 5.12 by (.52)*(9.8)
please help on everything else!
there are many.
so how fast was the projectile moving horizontally the entire time it was in the air?
and
how much time did the projectile spend in the air?
I believe you got answers for both of these. So if you know how fast it was going horizontally, and you know how long it was going that fast horizontally, then you can figure out how far (distance) the projectile went horizontally.
