Where Can I Find Baseline Data for Air Flow vs. Pressure in Valve Testing?
The discussion centers on finding baseline data for air flow versus pressure in valve testing. The user has set up a testing apparatus with a PVC pipe, air compressor, and transducers but lacks comparative baseline data for flow measurements. Suggestions include obtaining a calibration curve from Omega and referencing standards for valve flow rate testing, which involve measuring upstream and downstream pressures to calculate the valve coefficient (Cv). Alternatives like rotameters and orifice measuring stations are recommended for verifying flow meter readings. The conversation emphasizes the importance of understanding setup variables and measurement uncertainties in flow testing.
wxrocks
I am working on an air flow vs pressure chart for a variety of valve components for work and I am hoping someone may know where I could get some comparative baseline data.
My setup is a 4' long, 2" diameter PVC pipe with one end connected to a large air compressor tank with a ball valve for regulating the flow. Near the other end, I have an air flow transducer (Omega FMA-906) and a pressure transducer (Omega PX303). The end of the pipe is reduced by a series of graduated fittings that terminate at different ends that are designed to fit the valves I am testing.
I am able to check my pressure readings with an analog pressure gauge, but I don't have the same ability with the flow without significant setup changes. I am hoping there is some type of baseline data available for typical flows in a pipe with a constricted end. If anyone could point me to a resource for that data, that would be great!
What is the signal output from the flow meter? You should get a calibration curve from Omega. That's your check. Is there a reason why you don't trust the cal cert?
It sounds like you're trying to set up a flow test bench to determine the Cv of your valves, is that right? From reading this it sounds like you have an air tank, a ball valve on the tank outlet to regulate pressure or flow, a 2" pipe leading to a point that a valve is being tested, and I assume the outlet of the valve is venting to atmosphere.
There are some standards which cover flow rate testing for valves if that's what you're looking for. They basically tell you to measure upstream and downstream pressure on your valve and apply the equation to determine Cv. If your valves are various sizes such that your flow meter can't handle the full range, you should probably purchase a few different flow meters to handle the range. Electronic air flow meters of any kind are not cheap, so if you're concerned about cost, I'd suggest a rotometer.
turst in calibration
I do trust the calibration of the instrument -- It has more to do with the setup. Any setup will have different amounts of chaos and thus could affect the instrument reading depending on where it is located in the tube. I can certainly use the data I have, but I thought a "second" opinion would be nice.
Yes, this is venting to the atmosphere. And yes, my flow meter is sufficient to cover the flow amounts I need to test.
If you're just looking to back up the meter you have, a rotameter might suffice. It will get you to within a few percent for less than $100. Check out http://www.mcmaster.com/".
Granted your uncertainty will change slightly depending on the valve that is in line. However the "chaos" as you state it, inherent in the system will be eclipsed by the error in the measurements.
Depending on the expected range of velocities, you could also employ an orifice measuring station as a check.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
