Solving a Frictionless Pulley Problem: Acceleration of m2
To solve for the upward acceleration of block m2 in the frictionless pulley problem, apply Newton's second law to both blocks and the pulley. The net tension in the string is essential for determining the angular acceleration (α) of the pulley, which can be calculated using the moment of inertia (I) and the radius (R). Combining the equations from the forces acting on both masses and the pulley will allow for the acceleration to be derived. The initial approach of using tension alone was insufficient without considering all forces involved. A comprehensive analysis of the system is necessary to find the correct acceleration of m2.
physicsbro
A 29.3 kg block, m1, is on a horizontal surface, connected to a 6.70 kg block, m2, by a massless string as shown. The frictionless pulley has a radius R = 0.055 m and a moment of inertia I = 0.100 kg·m2. A force F = 202.5 N acts on m1 at an angle θ = 29.7°. There is no friction between m1 and the surface. What is the upward acceleration of m2?
My textbook says that the net tension divided by the moment of inertia would give me the \alpha and that multiplied by the radius would give me the acceleration, but it didnt work.
That's certainly true, but you'll need the tensions to make use of it. Hint: Apply Newton's 2nd law to both masses and the pulley. Combine those three equations and you can solve for the acceleration.
