Rolling Friction: Static, Kinetic, or Rolling?
In pure rolling motion, an object experiences static friction, as it rolls without slipping. If the object is only rotating and translating, it encounters kinetic friction if there is slipping. The friction force on a rolling body on a surface with a constant friction coefficient does vary with changing angular velocity, as it adjusts to provide the necessary linear and angular acceleration. The friction force can be expressed as f = k * Normal reaction, applicable when rolling with slipping occurs. Understanding these friction types is crucial for analyzing motion dynamics effectively.
sArGe99
When an object is said to be under pure rolling, what friction does it experience? Static, kinetic or rolling friction?
If its not rolling but rather just rotating and translating, what friction does it experience?
If a rolling body is kept on a surface of certain friction constant, does the friction force on it vary with changing angular velocity? Is the friction force still given by f = k * Normal reaction, which in the case mentioned is mg?
I appreciate any help.
If by "pure rolling" you mean "rolling without slipping", then it is static friction. I am not sure what "rolling friction" is.
Kinetic friction if it rolls with slipping (like a car "laying on the rubber" as it starts moving).
Yes if it rolls without slipping. The force of static friction will be whatever is necessary to provide the observed linear and angular acceleration.
Yes but only if there is rolling with slipping, i.e. if the instantaneous point of contact on the rolling object is not at rest with respect to the surface on which it rolls.
Good luck.:smile:
