Question about net force and acceleration
In the discussion, participants analyze a physics problem involving two blocks connected by a pulley system. The first question addresses calculating acceleration using the formula a = F/(m+M), where F is the applied force and m and M are the masses of the blocks. The second question considers how adding a pulley with an equivalent weight to the force F affects acceleration, leading to the conclusion that acceleration decreases due to the increased total mass. Participants clarify that the same force now has to accelerate three masses instead of two, confirming that the acceleration is indeed smaller in the second scenario. The final consensus is that treating the entire system as a whole helps in understanding the dynamics involved.
Alexstrasza
Picture related
[/B]
1. There is a system of two blocks tied to each other. There is a force F on the small block causing the system to move at a certain acceleration.
Find the acceleration.
2. (This is the one I'm not sure about) Instead of force F, we add a pulley with a weight that's equal to force F. Will the acceleration become smaller/bigger/remain the same?
F=ma
1. Net force = ma
a = Net force (F) / total mass (m+M) = F/(m+M)
2. Logically I feel like it doesn't matter "which force" pulls the system, to the right. But if we use the equation, then a = F/ total mass and in this case there are three masses instead of two, so acceleration is smaller?
Is this correct? I am confused...
Alexstrasza said:
Picture related
[/B]
F=ma
1. Net force = ma
Hi , i think all the block will be moving with the same acceleration and velocity. PF~ = ma projected on the x-axis . if they are lying on ground , but pulley problems , u must split the vectors i guess.
Became smaller, the acceleration that move M and m is given by the tension of the string that connect m and mx : T= (m + M)*a not more by F, because F acts also to the other mass that is falling, ( mx )
{ T= (M+m)*a
{F-T= mx * a
Solve this system for T and a
Alexstrasza said:
Picture related
[/B]
F=ma
1. Net force = ma
I'm not sure why you are confused. You have explained that in the second case the same force has more mass to accelerate, hence there will be less acceleration.
What makes you doubt your own analysis?
I was not sure that it is the same force. I thought maybe in the second case we need to add a force to the net force, like tension, that I missed.
This was a question on a test today and some students' answer was different from mine.
{ T= (M+m)*a
{F-T= mx * a
Okay, I see! The third mass is not the same as F force.
(M+m)a=F-mxa
(M+m+mx)a=F
a=F(M+m+mx)
Nice! So I got the answer right!
Thanks everyone. :)
If anything, an easier way you could look at that second situation is to just treat all 3 blocks as an entire system that has the same magnitude of force F that will cause all three blocks to accelerate. Since the weight of the mass hanging from the pulley is equal to the magnitude of force F, we know that the second system will have a lower acceleration because now it accounts for an extra mass, not just m and M.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
