Question from our Lab today on Friction
  • Thread starter Thread starter Husker70
    Friction Lab
The discussion revolves around understanding the coefficient of rolling friction for a car on an inclined plane moving at constant speed, expressed as mu = tan(theta) - m2/mc cos(theta). Participants express confusion about the problem and seek clarification on the variables involved, particularly m2 and mc. There is a consensus that the explanation of rolling friction in academic settings could be improved. The conversation emphasizes the need for clearer definitions and guidance to help students grasp the concepts better. Overall, the thread highlights the challenges students face in understanding complex physics problems.
Husker70
Assuming that f=mu(N), show that the cofficient of (rolling) friction for the
car moving down the inclined plane with a constant speed is given by
mu=tan(theta) - m2/mc cos(theta)(Use symbols, not numbers.)
Can someone explain any of this so I can understand what they are asking.
I can't get started because I don't really understand it.
Thanks,
Kevin
rolling
Hi Kevin! :smile:
(have a mu: µ and a theta: θ :wink:)
hmm … fair point! :biggrin:
I wish professors would explain rolling more carefully. :rolleyes:
Before I go any further, can you say what m2 and mc are (I can guess what θ is :wink:), and show us a bit more of the question? :smile:
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
