Random Thoughts 7
- Thread starter Evo
- Start date
2,059 replies · 118K views
Homework Helper
- 7,910
- 13,227
Wow, I helped my friend with what turned out to be a scarily, unusually-accurate model with her exercising. For one, the rate of .698 meters to a step ( her app uses meters), is accurate daily within less than 5-6 meters, for walks of several kilometers, according to her tracker app. So, say, 5500 steps will correspond to 3843 metters, only slightly above the 3839 metters expected. I thought the total would vary more than that.
Homework Helper
- 3,447
- 3,752
WWGD said:Wow, I helped my friend with what turned out to be a scarily, unusually-accurate model with her exercising. For one, the rate of .698 meters to a step ( her app uses meters), is accurate daily within less than 5-6 meters, for walks of several kilometers, according to her tracker app. So, say, 5500 steps will correspond to 3843 metters, only slightly above the 3839 metters expected. I thought the total would vary more than that.
Does the app use GPS to track her route? If so, I would expect it would be pretty accurate (i.e., the 0.698 m/step would have been calculated based on the GPS measured length of the route*, and not the other way around).
* Edit: and the number of steps, which can be recorded and counted based on the device's accelerometer.
Homework Helper
- 7,910
- 13,227
Good point. Not sure on the GPS issue. Will look it up.collinsmark said:Does the app use GPS to track her route? If so, I would expect it would be pretty accurate (i.e., the 0.698 m/step would have been calculated based on the GPS measured length of the route*, and not the other way around).
Homework Helper
- 7,910
- 13,227
Annoying misunderstanding about the song "Under Pressure". No, I meant the one by ZZ Top, not the one by Queen.
Whatever they may say about Yes, 90125 is the only music I've been able to read in a focused way for more than 10 minutes.
- 10,069
- 5,276
Just trying to calmly drive to a party yesterday. I hate driving in traffic.
It took him about six seconds to get 7 or 8 lane markers ahead. Assuming about 30 feet for each section, it works out to about a 35-40 MPH speed differential. I was going with the flow of traffic at about 60-65 MPH so he was somewhere around 100+MPH.
I knew that I had enough space to merge in front of the car that I was passing but I was carefully checking my mirrors. I only saw him when he was about two car lengths back. You can see that I slightly swerve to the right just before he passed me. I see a lot of drivers who just swerve into a lane when they're changing lanes. If I had done that, it would have been a completely different story.
- 16,815
- 19,385
- 15,622
You are dating yourselfBystander said:"..., get your kicks...."
- 19,385
- 15,622
I believe that was because it was no longer a major thoroughfare across the country. Sections of it were closed when the Interstate Highway system went in.WWGD said:It was somehow " removed" from the US highway system. Couldn't get much on what that meant.
Staff Emeritus
2025 Award
- 22,716
- 7,814
A 101-year-old woman keeps getting mistaken for a baby on flights, and says it's because American Airlines' booking system can't handle her age
https://news.yahoo.com/101-old-woman-keeps-getting-102214114.htmlThe computer can't process that Patricia was born in 1922, not 2022.
Staff Emeritus
2025 Award
- 22,716
- 7,814
Intel issues statement about CPU crashes, blames motherboard makers — BIOSes disable thermal and power protection, causing issues
https://news.yahoo.com/tech/intel-issues-statement-cpu-crashes-193504163.htmlIgor's Lab seems to have obtained a message originally destined for motherboard manufacturers concerning a prolonged stability issue on the company's 13th Generation Raptor Lake and 14th Generation Raptor Lake Refresh chips, which rank among the best CPUs. It made sense for the company to clarify the issue where many blamed the motherboard manufacturers in a race to become 'the fastest' performer by having over-aggressive voltages for allowing higher clock speeds.
The company specifically points out the issue with 600/ 700 series motherboard manufacturers that disable thermal and power protection to achieve the highest possible overclocks, even at the cost of instability. The chipmaker said in the message:
That would be annoying for someone whose livelihood depends on a functioning computer. That's probably most of us.
Homework Helper
- 7,910
- 13,227
She had her personal Y(0.1)K problem.Astronuc said:A 101-year-old woman keeps getting mistaken for a baby on flights, and says it's because American Airlines' booking system can't handle her age
Klystron
- 1,980
How so, Dubya-dubya? Also, which secure first or second tier search engine do you prefer?WWGD said:Wow, Duckduckgo may not track you, but there's a price to pay. Search results are 3rd tier at best. At least non-trivial ones.
(Apologies for responding to an older post. Still recovering from major surgery late in 2023.)
Homework Helper
- 3,447
- 3,752
Astronuc said:Intel issues statement about CPU crashes, blames motherboard makers — BIOSes disable thermal and power protection, causing issues
Yep. There's truth to this. I've known about this for about a month now, being as I try to keep up on such things since I build my own computers.
It's worse than causing "crashes," though: it places the CPU (and indirectly the associated cooling systems) at a too aggressive operating point that could, over time, reduce the longevity of the systems. Not to mention waste power and muck up performance from inevitable CPU frequency throttling, and maybe eventually cause some crashing in the long run.
Here's a JayzTwoCents video demonstrating the problem and how to fix it, using an ASUS motherboard as an example. It's an easy to fix solution in the BIOS, although going into the BIOS is asking a lot (probably too much) for the average computer owner/user.
But yeah, it's bad and shouldn't* happen.
*(I mean that as a normative claim, as in "it aught not be something that should happen, even if it is actually happening.)
Homework Helper
- 7,910
- 13,227
Well, when I ask for, e.g., movie times for, say, movie x on October 2023, I get results for cities y,z,w on June of 2017.Klystron said:How so, Dubya-dubya? Also, which secure first or second tier search engine do you prefer?
Have a fast recovery. And Hava Nagila/Tequila.
Homework Helper
- 7,910
- 13,227
Ive seen arguments, claims, to the effect that only some types/breeds of dogs help prevent or fight break ins. Their general friendliness doesn't help in this respect.Borg said:An animated ad that I saw on msnbc web site this morning. Soooo many questions about this dog and its owner.
Homework Helper
- 7,910
- 13,227
People are amazed at my being able to figure out if a number is divisible by 7 even after I show them an easy trick. Just partition a number, so that each part is divisible by 7. Then, e.g., 2849, 2863 , are both divisible by 7, since each of 28, 49 , and 63 are. Similarly, 1751 is,divisible by 17. But then again, the person expressing amazement is someone who says " wow, so close!" when dividing a number by 2 and seeing a reminder of 1.
- Evo
- · Replies 11K ·
- Other Physics Topics
- Replies
- 11K
- skyshrimp
- · Replies 5 ·
- Replies
- 5
High School
Random thoughts on Fibonnacci sequence
- parshyaa
- · Replies 4 ·
- General Math
- Replies
- 4
- Raghav Gupta
- · Replies 8 ·
- Biology and Medical
- Replies
- 8
- ThomasT
- · Replies 25 ·
- Electromagnetism
- Replies
- 25
- Cait
- · Replies 1 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 1
- Fra
- · Replies 3 ·
- Quantum Interpretations and Foundations
- Replies
- 3
- kyphysics
- · Replies 52 ·
- Replies
- 52
- EternalStudent
- · Replies 1 ·
- STEM Academic Advising
- Replies
- 1
Undergrad
Random thought about force and motion
- tadpole
- · Replies 7 ·
- Mechanics
- Replies
- 7
