Relating Electric Field and Magnetic Field
Protons moving in a 0.536 T magnetic field with a radius of 7.70 cm can have their paths straightened by applying an electric field that balances the magnetic force. The relationship between electric field (E) and magnetic force (F) is given by the equation qvB = qE, indicating that the electric force must equal the magnetic force for straight-line motion. To find the velocity of the protons, the equation v = rqB/m can be used, where r is the radius, B is the magnetic field strength, and m is the mass of the proton. After calculating the velocity, the force can be determined using F = qvB, which then allows for the calculation of the electric field using E = F/q. Understanding the Lorentz Force is crucial for analyzing the net force on charged particles in both electric and magnetic fields.
PeachBanana
Protons move in a circle of radius 7.70cm in a 0.536 T magnetic field. What value of electric field could make their paths straight?
Unsure
r = 0.0770 m
B = 0.536 T
m = 1.6*10^-27 kg
q = 1.6*10^-19 C
E = F / q
I'm not sure how to get force without a velocity.
Hi PeachBanana,
Consider the answers to these questions:
If both an electric and magnetic field are present, how can you write the net force on the proton?
In order for the proton to move in a straight line, the net force on the proton must be what?
What kind of velocity does the proton have when it's circling around in a magnetic field? And what is the equation for that kind of velocity?
This should give you a hint:
http://en.wikipedia.org/wiki/Cyclotron_motion
What should be the direction and magnitude of electric field so that protons go in straight direction?
If the force due to electric field is opposite to the direction of force and equal in magnitude to force exerted by the magnetic field, the protons go in a straight path.
i.e qvB=qE.
To get the velocity, i guess you are given sufficient data, what is the relation between velocity and radius?
I have now come up with:
qvB = mv^2 /r
qb = mv/r
v = rqB/m
v = (0.0770 m)(1.9*10^-19)(0.536 T) / (1.67 * 10^-27 kg)
v = 4.0*10^6 m/s
Hmm.
Just realized I solved for the wrong variable completely. Since F = qvb and I know "v," I can solve for "F." When I know "F", I can then use the fact that E = F/q.
Edit: Ah yes, I see what you're doing. That should give you the correct numerical answer. Just make sure you specify the directions of the fields. For future reference, you should look at the Lorentz Force. This is the net force on a charged particle when both electric and magnetic fields are present.
