Relation between angular displacement and tension.
The discussion focuses on measuring the tension in a timing belt using a dial gauge indicator, but the original poster is seeking a formula to relate angular displacement to tension. Participants note the lack of detail regarding the setup, particularly what generates the tension. Suggestions include providing a visual representation of the setup and considering the use of a spring scale for direct force measurement. The conversation emphasizes the need for more information to establish a clear relationship between displacement and tension. Overall, understanding the mechanics involved is crucial for accurate tension measurement.
rambharath94
Hello guys,
Iam doing a project to find the tension of timing belt using a dial gauge indicator(consists of plunger and gear attached to it ie;rack and pinion mechanism) ,but i can't find a formula relating the displacement of the pointer and the tension (eg: 5° of dislplacement of pointer = 10 units of tension?).Please help me...
Hi rambharath94,
Your details are a bit short on a clear explanation of your setup. A picture might help.
As i understood thus far you wish to measure the tension in a timing belt, although you give no details of what is creating that tension (a weight or something to create torque?).
Also you have means to measure the angle or stretch of the belt via a dial gauge.
If you can measure geometrical properties, can you get your hands on a spring scale for measuring a force?
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
