Resultant of thirty vectors of a polygon
To determine the resultant of thirty vectors, each with a magnitude of 2N, represented by the sides of a regular polygon, the interior angle is calculated to be 168°. The components along the X and Y axes are derived using trigonometric functions based on this angle. The resultant is found by summing these components and applying the equation R² = Rx² + Ry². A participant expresses concern about the lengthy process and seeks a simpler method for solving such problems. The discussion also touches on the concept that if vectors are arranged head-to-tail in a closed polygon, their sum equals zero.
sadaf2605
University Physics(12th ed) said:
Thirty vectors, each of magnitude 2N, are represented by the sides of a regular polygon taken in order. Determine their resultants.
equation, square of resultant, R2 = Rx2 + Ry2
interior angle of a polygon = (n-2)* 180°/n
= (30 - 2)* 180°/30
= 168°
components on X axis:
Ax1 = 20* cos 168°
Ax2 = 20* cos (168°+168°)
Ax30 = 20* cos (168° * 30)
Rx = Ax1 + Ax2 + . . . +Ax30
components on Y axis:
Ay1 = 20* sin 168°
Ay2 = 20* sin (168°+168°)
Ay30 = 20* sin (168° * 30)
Ry = Ay1 + Ay2 + . . . +Ay30
thn,
R2 = Rx2 + Ry2
i think we can solve this kind of problem this way, but this process is so lengthy so i am expecting some alternative easy and short way to solve such problems, anyone to help?
I'm not sure I understand the problem.
If you add any number of vectors head-to-tail, and the head of the last one meets the tail of the first one, then the sum is always zero.
Thanks alot!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
