Rquired bolt size to support gantry
  • Thread starter Thread starter blizzard95
    Bolt Support
The discussion centers on calculating the required bolt size for a gantry system with a horizontal beam bolted to the face of two upright I-beams. Participants emphasize that the horizontal beam should be treated as a fixed beam rather than simply supported, as this affects the reactions and shear stress on the bolts. It is noted that bolts should primarily experience tension rather than shear, with the joint's friction resisting shear forces. The importance of consulting an engineer for proper design and safety is highlighted, given the complexities involved in bolt selection and connection details. Proper understanding of deflection and slope in beam theory is crucial for ensuring structural integrity.
blizzard95
Hello all,
Just thinking of this in my head, and maybe over thinking it. First a description of the problem,If i have two upright I beams, and an I beam spanning from one to the other. The horizontal beam isn't sitting on top of the two uprights, but bolted to the face of them. In calculating the force acting downwards at each end of the horizontal beam, do i just treat this as a simply supported at both ends and calculate the upward reactions at each, and use this as the force to calculate the shear stress in the bolts.
Thanks in advance for all replies
If you have more than one bolt at each end of the horizontal beam, the reactions on the bolts will combine in part to develop a reactive moment to whatever load is present on the cross member; i.e. the cross member will not be free to rotate, and a simple support condition (slope = deflection = 0) cannot exist.
There are specialized codes and design procedures for selecting bolts and working out the connection details. If you are not an engineer, it is recommended that you consult one to make sure your connections are safe.
Correction: The simple support condition is deflection = 0, but the slope is not equal to zero.
In order for a bolted, rigid (or fixed) connection to exist, then deflection = slope = 0.
My 2 cents.
I'd treat it as a beam fixed on both ends. http://en.wikipedia.org/wiki/Fixed_end_moment
The bolts should not see a shear load. If your bolts see any meaningful amount of shear, the joint has basically failed. They should only be in tension. The friction of the joint interface is what resists the shear force. When the beam is loaded, it's deflection will put additional tensile stress on the bolts.
So first and foremost, I'd look at the friction forces needed at the interface.
Thanks for your replies,
Why will the slope not be equal to zero, when the deflection is zero?
To be clear, for a simply supported condition at the ends of the cross member, the deflection will be zero but the slope at the ends cannot be zero since there is nothing the restrain the rotation of the beam at the ends.
If the joint were truly simply supported at the ends of the cross member, there would be nothing which could keep the ends from rotating when a load was applied to the cross member. It's like placing a board across two saw horses, where the board overhangs each saw horse: If you put a load in the middle of the board, the board drops under the load and the ends of the board come up at either end. If you want to make the slope at the ends equal to zero, you must either clamp the ends of the board or put additional loads outside of the saw horses to create an additional bending moment which brings the slope at each saw horse back to the horizontal.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
