Calculating Force Needed to Distort Steel Plate
In summary, the conversation discusses the calculation of force needed to distort the edges of a 10 cm square steel plate by 0.04 cm, with a thickness of 0.25 cm. The sheer modulus for steel is given as 80 * 10^9 n/m^2 and the equation to calculate the force needed is F/A = G * Delta H/H, where G is the shear modulus, F is force, A is area, and Delta H and H refer to the change in length and original length, respectively.
samemikejones
A steel plate of 10 cm square or (100 sq cm) is .25cm thick. How much force is need to distort its edges by 0.04 cm.
sheer modulus for steel is 80 * 10^9 n/m^2,
Plz Help Thanx
Remember that the sheer (or shear) modulus is given by stress divided by strain.
Where Stress is Force/Area.
And Strain is the Change in Length / Original Length.
This should be enough to get you going.
Not sure if that equation is right, because they give you the shear modulus in the question, so I found an equation with G in it, F/A = G * Delta H/H, the other equation does not have G in it
If G is the shear modulus, then the equation that you have written:
is exactly the same as what I wrote in my last post.
Related to Calculating Force Needed to Distort Steel Plate
What is the formula for calculating the force needed to distort a steel plate?
The formula for calculating the force needed to distort a steel plate is F = (3*E*t^2*L)/(2*w), where F is the force, E is the elastic modulus of steel, t is the thickness of the plate, L is the length of the plate, and w is the width of the plate.
What is the elastic modulus of steel?
The elastic modulus of steel is a measure of its stiffness or resistance to being deformed elastically. It is typically given in units of force per unit area, such as pounds per square inch (psi) or megapascals (MPa). The elastic modulus of steel can vary depending on the type and grade of steel, but it is usually around 200 GPa (29,000,000 psi).
How does the thickness of the steel plate affect the force needed to distort it?
The thickness of the steel plate directly affects the force needed to distort it. As the thickness increases, the force needed to distort the plate also increases. This is because a thicker plate has a larger cross-sectional area, which means it can withstand more force before it is distorted.
What other factors besides force can affect the distortion of a steel plate?
Besides force, other factors that can affect the distortion of a steel plate include the type and grade of steel, the temperature, and the shape of the plate. Different types and grades of steel have different elastic moduli, which can affect the amount of force needed to distort them. Temperature can also impact the elasticity of steel, making it easier or harder to distort. Lastly, the shape of the plate can also affect its resistance to distortion, as certain shapes may distribute force more evenly across the plate.
Can the force needed to distort a steel plate be calculated accurately?
The formula for calculating the force needed to distort a steel plate is based on certain assumptions and simplifications, so it may not always provide an accurate estimation. Other factors, such as the type of loading and the presence of imperfections in the plate, may also affect the actual force needed. To get a more precise calculation, real-world testing and analysis may be necessary.
11K
