Simple Applications of Macroscopic Thermodynamics
vladittude0583
The following describes a method used to measure the specific heat ratio "gamma" of a gas. The gas, assumed ideal, is confined within a vertical cylindrical container and supports a freely moving piston of mass m. The piston and cylinder both same the same cross-sectional area A. Atmospheric pressue is p0, and when the piston is in equilibrium under the influence of gravity (acceleration g) and the gas pressure, the volume of the gas is V0. The piston is now displaced slightly from its equilibrium position and is found to oscillate about this position with frequency "nu." The oscillations of the piston are slow enough that the gas always remains in internal equilibrium, but fast enough that the gas cannot exchange heat with the outside. The variations in gas pressure and volume are thus adiabatic. Express "gamma" in terms of m, g, A, p0, V0, and "nu"
pV(gamma)=constant.
1) Since the gas cannot exchange heat with the outside, then I know that Q = 0 right?
2) When the piston is in equilibrium under "g" and the gas pressure, the force from the gas has to exactly balance out the gravitational force due to the piston right?
3) Do I have to take into consideration of potential energy in terms of oscillatory motion?
4) Since Q = 0, then we know that the change in energy is equal to the work done right?
5) Any advice towards the correct direction to solving this problem would be greatly appreciated.
6) Thanks!
Sinusoidal oscillations generally occur when there's a restoring force that increases with displacement. In this case, the pressure increases slightly when the volume decreases due to the piston moving downwards, and this causes the piston to rebound. You'll probably want to look into the relationship between this restoring force and the frequency of oscillation.
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
