Calculating Coefficient of Kinetic Friction in a Hockey Game
  • Thread starter Thread starter xenograftsoul
    Friction
To calculate the coefficient of kinetic friction between a hockey puck and ice, the initial kinetic energy of the puck must be equated to the work done against friction. The frictional force is determined by the coefficient of friction multiplied by the normal force, which is the puck's mass times gravity. By using the puck's initial speed of 10 m/s and the distance of 50 m it slides before stopping, the average acceleration can be calculated. A key insight is that the mass cancels out in the equations, allowing for the coefficient of friction to be expressed without units. The final calculations lead to a corrected understanding of the relationship between acceleration, distance, and the coefficient of friction.
xenograftsoul
During a hockey game, a puck is given an initial speed of 10 m/s. It slides 50 m on the ice before it stops. What is the coefficient of kinetic friction between the puck and the ice?
A. 0.090
B. 0.10
C. 0.11
D. 0.12 I'm taking an online class and unless I've missed something friction hasn't come up yet in the lessons but is in the quiz. If I remember correctly though (from high school physics) you need some mass or normal force for it.
Is this answerable as is?
Thanks for any help.
A. 0.090
B. 0.10
C. 0.11
Well, here are some hints: The initial kinetic energy of the puck goes into the work to overcome friction. Work is equal to force times distance. The frictional force is equal to the coefficient of friction times the normal force acting between the puck and the ice. That force is given by the mass of the puck times the acceleration of gravity. Now assemble all these pieces and you will find that you can solve for the coefficient of friction. (There will be a fortuitous cancellation along the way)
okay, so far I believe
50m=10m/s / 2 *Time^2 solve for Time gives the time it takes to stop (sqrt10)
10m/s divided by Time= average acceleration (again sqrt10 or 3.16)
3.16m/s^2 * mass = the frictional force = the coefficient of friction * mass * g
I believe that force is also equal to the force in work (equal but opposite).
work = force * distance
work = 3.16m/s^2 * mass * 50mSolving for the coefficient here though still seems fruitless:
3.16m/s^2 * mass =
yup. there was that "and now I feel like an idiot" moment.
3.16m/s^2 * mass = coefficient of friction * mass * 9.8m/s^2
there, now the masses cancel and 3.16m/s^2 divided by 9.8m/s^2 gets rid of the m/s^2
(I am correct in my understanding that the coefficient should be without units)
but that leaves me with sqrt10/9.8 = .32
Have I fumbled somewhere or was this all a red herring?
you have written that
distance = average velocity*time^2 [/color]. Correct this and you'll be OK.
okay, that makes everything better. That was a silly mistake. Thanks for all the help.
