Simple lab calculation (Magneticfield vectors)
The discussion focuses on calculating the Earth's magnetic field density (B) using a lab setup involving a current of 2.89 amps flowing through a rod positioned parallel to the Earth's magnetic field. The proportionality constant used is 2 x 10^-7, and the compass needle deviates 55 degrees due east. The calculated magnetic field density for the X component is 1.651428571 x 10^-5 Tesla, leading to a resultant vector (B-res) of 2.016022035 x 10^-5 Tesla. The Y-component is derived using Pythagorean theorem, resulting in approximately 12 microTesla.
  • Understanding of magnetic field calculations using the formula B = K X I / r
  • Basic trigonometry, specifically cosine and tangent functions
  • Familiarity with vector components and their calculations
  • Knowledge of Tesla as a unit of magnetic field density
  • Learn about the Biot-Savart Law for magnetic field calculations
  • Explore vector addition in physics for complex magnetic field scenarios
  • Study the implications of magnetic field strength on compass behavior
  • Investigate the effects of varying current on magnetic field density
Students in physics, particularly those studying electromagnetism, as well as educators and anyone involved in laboratory experiments related to magnetic fields and vector analysis.
Xeno24
I = 2.89amps, r = 0.035m, resultant vector angle (55), proporptionality constant (2 x 10^-7)
B = K X I / r , trigonometry, vector divisions.
Hi, I'm just pasting this off my lab to make sure I've done it correctly. Thanks in advance.
Lab:
A rod is put, parallel to the Earth's magnetic field (due north)with a compass needle 0.035m below it. A flow of 2.89amps is switched on and the compass needle deviates 55 degrees due east as the current creates a magnetic field of its' own.
Question - Calculate the Earth's magnetic field density (B) using these vectors.
Using the formula above the field density for the X component is
(2 x 10^-7) x 2.89amp
------------------------------ = 1.651428571 x 10 ^- 5 Tesla
0.035m
To find the resultant vector (B-res), I used
Cos(35) = B-x/B-res, B-x/Cos(35) = B-res,
----------------------------------- = B-res
Cos(35)
B-res = 2,016022035 x 10^-5 T
And finally with Pythagoras you can find the vector of the Y-component,
______________
\/B-res^2 – B-x^2 = 1,156342737 x 10^-5 T
~ 12microT
Since the compass stays in the resultant vector (Bres),
Looks good. You could also use the fact that
tan(35 deg) = ____ / ____ ?
which gets you from Bwire to Bearth in a single step, without the need to calculate Bres.
p.s. welcome to PF :smile:
Thanks. :)
