Simple Volume Problem: Solving for x and Rotating a Region around the Y-Axis
  • Thread starter Thread starter mewmew
    Volume
The discussion revolves around solving a volume problem by rotating a region in the first quadrant, defined by the equations y=x^3 and y=2x-x^2, around the Y-axis. The user successfully solved for x, obtaining x=√[3]{y} and x=1-√(1-y), but struggles with integrating the resulting expression. They suspect an error occurred during the integration process, particularly with the term (1-√(1-y))^2 and its evaluation. Another participant confirms the integration appears correct but highlights the quadratic nature of the equation y=2x-x^2, suggesting a potential oversight in evaluating the integral. The user acknowledges a mistake in evaluating the integral at the limits, indicating a common issue with integration errors.
mewmew
Ok,so I have a simple volume problem that I'm having a little trouble with.
I want to rotate the region in the first quadrant bounded by the following formulas around the Y axis.
<br /> y=x^3
y=2x-x^2
I solved for x and got
<br /> x=\sqrt[3]{y}
x=1- \sqrt{1-y} I know I get two roots but I am pretty sure this is the one I want.
I do have one question here, when given such equations as y=2x-x^2 how do you go about solving for x? I used Mathematica because I couldn't get it, but anyways back to the main problem.
so I then did \pi \int^1 _0 \sqrt[3]{y}^2 - (1- \sqrt{1-y})^2 dy
I expanded (1- \sqrt{1-y})^2 and then integrated the expresion and got the following:
\pi [\frac{3y^\frac{5}{3}}{5} - 2y - \frac{4}{3} (1-y)^{\frac{3}{2}}+\frac{y^2}{2}]^1_0
This isn't right however and I assume I messed up somewhere in my final integration, any help? Thanks a lot. I am also going to assume it has to do with (1- \sqrt{1-y})^2, I did U substitution on the term 2 \sqrt{1-y} and am thinking I messed that up, but once again, am not sure. The only other thing I can think about is maybe I missed up my functions somehow. Thanks for any help.
It's a quadratic in x:
x^2-2x+y=0 \Rightarrow x=1\pm \sqrt{1-y}
At a first glance,your integration seems okay.
Daniel.
Oh, sorry, I think I just messed up evaluating it, I forgot that all the terms aren't 0 when it is evaluated at 0...I make the dumbest mistakes! :blushing:
