Solve 1-D Motion Problem: Find Vo & a
  • Thread starter Thread starter kfink85
    Motion
The discussion focuses on solving a 1-D motion problem involving a truck that decelerates while covering 40.0 m in 8.50 s, ending with a speed of 2.80 m/s. Users initially struggled with the equations of motion but found the average speed to be 4.71 m/s, which helped in calculating the initial speed. One participant calculated the initial speed as 6.62 m/s and the acceleration as -0.45 m/s². Others confirmed the calculations, indicating that the approach and results were correct. The thread highlights the importance of using average speed to simplify the problem-solving process.
kfink85
A truck covers 40.0 m in 8.50 s while smoothly slowing down to a final speed of 2.80 m/s. (a) Find the truck's original speed. (b) Find it's acceleration.
I used the 2nd formula originally (X=VoT+1/2aT^2) but I wasn't getting anywhere. Can someone point me in the right direction on how to do this problem? Any help is appreciated. Thanks.
Try figuring out the average speed of the truck and see what that tells you.
I found it to be 4.71 m/s but I'm still stuck. Where do I go next?
Good. Now use that to find the initial speed:
v_{ave} = (v_i + v_f)/2
Thanks for your help. I really appreciate it.
I got 6.62 m/s for part A and used V=Vo+at to get -.45m/s^2 on part B.
I hope this is correct. I'm pretty sure A is.
Can anyone confirm?
Looks good to me.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
