Solve Rotation Questions: 2.53 Revs in 6.28 & 19.3 Secs
  • Thread starter Thread starter shell4987
    Rotation
The discussion revolves around solving a physics problem involving a merry-go-round's rotation with an angular acceleration of 1.65 rad/s². The initial attempts to calculate the time for the first and second 2.53 revolutions were incorrect due to unit conversion errors, specifically not converting revolutions to radians. The correct approach involves using the equation relating angular displacement, initial angular velocity, time, and angular acceleration. After correcting the unit conversions, the revised calculations yield approximately 1.75 seconds for the first 2.53 revolutions and 2.48 seconds for the next 2.53 revolutions. Accurate unit consistency is crucial for solving rotation problems effectively.
shell4987
A merry-go-round rotates from rest with an angular acceleration of 1.65 rad/s2. How long does it take to rotate through (a) the first 2.53 rev and (b) the next 2.53 rev?
I tried to do this and I converted the rev to radians by multiplying the revolutions by 2pi and then for (a) I divided 15.896/1.65 and got 6.28 seconds (15.896 is 2.53(2pi))and for (b) I divided 31.79/1.65 to get 19.3 seconds. What am I doing wrong here?
Check your units, this doesn't work out to seconds.
What equation relates time, angular displacement, and angular acceleration?
theta-theta initial= w initial(t) + (1/2)at^2?
What do you get for the time with that equation?
For (a) I got 1.75seconds and for (b) I got 2.48 seconds. I used 2.53 as the first displacement and for w I put in 0 and for acceleration I put 1.65 and then solved for t and that's what I got, and for the second part I put in 5.06 for the displacement. What am I doing wrong?
You need to change this into radians before using it in your calculations. Your units are not consistent otherwise. Try part (a) again with that change.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
