Solve Rotation Questions: 2.53 Revs in 6.28 & 19.3 Secs
  • Thread starter Thread starter shell4987
    Rotation
The discussion revolves around solving a physics problem involving a merry-go-round's rotation with an angular acceleration of 1.65 rad/s². The initial attempts to calculate the time for the first and second 2.53 revolutions were incorrect due to unit conversion errors, specifically not converting revolutions to radians. The correct approach involves using the equation relating angular displacement, initial angular velocity, time, and angular acceleration. After correcting the unit conversions, the revised calculations yield approximately 1.75 seconds for the first 2.53 revolutions and 2.48 seconds for the next 2.53 revolutions. Accurate unit consistency is crucial for solving rotation problems effectively.
shell4987
A merry-go-round rotates from rest with an angular acceleration of 1.65 rad/s2. How long does it take to rotate through (a) the first 2.53 rev and (b) the next 2.53 rev?
I tried to do this and I converted the rev to radians by multiplying the revolutions by 2pi and then for (a) I divided 15.896/1.65 and got 6.28 seconds (15.896 is 2.53(2pi))and for (b) I divided 31.79/1.65 to get 19.3 seconds. What am I doing wrong here?
Check your units, this doesn't work out to seconds.
What equation relates time, angular displacement, and angular acceleration?
theta-theta initial= w initial(t) + (1/2)at^2?
What do you get for the time with that equation?
For (a) I got 1.75seconds and for (b) I got 2.48 seconds. I used 2.53 as the first displacement and for w I put in 0 and for acceleration I put 1.65 and then solved for t and that's what I got, and for the second part I put in 5.06 for the displacement. What am I doing wrong?
You need to change this into radians before using it in your calculations. Your units are not consistent otherwise. Try part (a) again with that change.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
