Solving Newton's Laws Problem: Baseball Player & Runner
  • Thread starter Thread starter ash312
    Laws Newton
A baseball player hits a ball straight up at 18.0 m/s, and the runner on third base starts running towards home plate, which is 27.4 m away. To solve the problem, it's essential to determine how long the ball takes to return to its initial height, which can be calculated using the formula for free fall. The time for the ball to ascend and descend is approximately 3.67 seconds. Given the runner's speed of 7.60 m/s, he will cover about 27.4 m in approximately 3.61 seconds, meaning he will reach home plate just before the ball returns. The runner will be slightly ahead of home plate when the ball descends back to its original height.
ash312
A baseball player hits the ball straight up in the air with a velocity of 18.0m/s. As soon as the ball is hit, the runner on third base dashes toward the home plate. The distance between third base and home plate is 27.4m. Where will the runner be with reference to home plate when the ball returns to its initial height?
I am not sure
Dont understand how to start the solution
How long does it take for the ball to come down? How far does the guy run in this time? (Note that without the speed of the runner, it's impossible to answer this question. The answer will be very different if he's running at the speed of continental drift than if he's running at the speed of light)
The guy runs at 7.60 m /s
OK, so how long does it take for the ball to come down?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
