Why Are These Dynamics Problems So Challenging?
  • Thread starter Thread starter akademiks
Dynamics problems can be particularly challenging due to the need to understand forces, friction, and motion. In the first scenario, to keep a 16kg table moving at constant velocity on a surface with a coefficient of kinetic friction of 0.61, the applied force must equal the frictional force. If the applied force is 109N, the time to travel 75cm can be calculated using the table's acceleration. In the second scenario, to determine the smallest mass of a box that remains at rest under a 21N force at a 31-degree angle, one must analyze the balance between static friction and the applied force. Drawing force diagrams and considering the effects of angles and friction coefficients are crucial for solving these problems effectively.
akademiks
Some Dynamics Questions
I've been working at these stupid questions for hours and i just can't figure them out. Someone please help.
1) A student is pushing horizontally on a table (m = 16kg) to move it across a horinzontal floor. The coefficient of kinetic friction between the table and the floor is 0.61
a) Determine the magnitude of the applied force needed to keep the table moving at a constant velocity.
b) If the applied force were 109N and the table were to start from rest, how long would the table take to travel 75cm?
2) A rope exerts a force of magnitude 21N, at an angle 31 degrees above the horizontal, on a box at rest on a horizontal floor. The coefficients of friction between the box and the floor are uS (Coefficient of Static Frict) = 0.55 and uK (coefficient of Kinetic friction) = 0.50. The box remains at rest. Determine the smallest possible mass of the box.
I'd need this help in less than an hour though, so Thanks
Hints:
Question (1)
(a)
What are the forces on the table?
What can you say about the net force if the table is moving at constant velocity?
(b)
Can you find the acceleration? Is it constant?
Given the acceleration, how can you calculate distance travelled?
2.
What can be said about the friction force vs. the applied force if the box doesn't slide?
How are you going to deal with the angle?
Have you drawn a force diagram?
Think about these things, and get back if you still have problems.
