Specific Heat Capacity Problem.(Please check.)
The discussion addresses a calorimetry problem involving a metal bolt and water, where the initial temperature of the bolt is unknown. The calculations show that the change in temperature of the metal is -55.87°C, indicating it cools down when placed in water. This leads to the conclusion that the initial temperature of the metal is +80.87°C, as the heat gained by the water equals the heat lost by the metal. The confusion arises from the sign convention in heat transfer, emphasizing that the net thermal energy change for the system is zero. Understanding this concept is crucial for explaining the problem to students.
shulien
This is CALORIMETRY PROBLEM.
A 0.050kg metal bolt is heated to an unknown initial temperature. It is then dropped into a beaker containing 0.15kg of water with an initial temperature of 21.0 C. The bolt and metal then reach a final temperature of 25.0 C. If the metal has a specific heat capacity of 899 J/kg*C, find the initial temperature of the metal.
the solution is:
Change in Temp of metal = (C of water *mass of water* Change in temp of water)/(C of metal*mass of metal)
Change of temp. of metal = [(4186 J/kg*C)(0.15kg)(25C-21C)]/[(899 j/kg*C)(0.050kg)
Change of temp. of metal = 55.87C
Change in temperature = Final Temperature-Initial Temperature
Initial Temperature = Final Temp.-Change in Temp
=25C-55.87C
= -30.87C
i want to ask why is the answer +80.87C from the book, instead of -30.87C?
i hope you could explain so i can also explain it to my students. is the sign of the answer has something to do with the HEAT REMOVAL and HEAT ABSORPTION?
Thanks!
shulien said:
the solution is:
This is off by a minus sign. The net change in thermal energy of "metal + water" is zero, so:
Change in Temp of metal = - (C of water *mass of water* Change in temp of water)/(C of metal*mass of metal)
Change of temp. of metal = [(4186 J/kg*C)(0.15kg)(25C-21C)/[(899 j/kg*C)(0.050kg)
The change in temp of the metal is -55.87C, not +. (The metal cools down.)
=25C-55.87C
= -30.87C
25C - (-55.87C) = +80.87C
Just keep in mind that the "heat" gained by the water must equal the "heat" removed from the metal. In terms of Q: For the water, Q = + (it heats up); for the metal, Q = - (it cools down). The net Q is zero.
thanks for the reply.
:smile:
