How do I calculate specific heat capacity in a lab report?
In summary, the conversation discusses two different problems related to heat capacity and using the formula q=c*m*ΔT to solve them. The first problem involves finding the heat capacity of ethylene glycol given its mass and temperature change, while the second problem involves finding the heat gained by water and the heat capacity of a metal using its mass and temperature changes. The person asking for help is struggling to understand the formula and is seeking guidance.
soccerLuver
i have a problem solving this foe my lab report..i just don't get the formula
heres the data:
ethylene glycol...its mass is 200 g ,initial temperature 22C, temperature after heated 100C
what is its heat capcity?
metal and water
mass of metal-15.8 g
temperature of water-23 C
temperature of metal and washers-24 C
what is the heat gained by the water assuming the heat gained by the water is equal to the heat lost by the metal?
what is the heat capacity of the metal?
any clue..or formula?
200( 1cal/gC) (1) / 15.8 (1)
In general, formula that you are looking for is most likely
q=c*m*ΔT
methods
(1) = 12.66 cal/gC
To solve these specific heat problems, we need to use the formula Q = mcΔT, where Q is the heat gained or lost, m is the mass of the substance, c is the specific heat capacity, and ΔT is the change in temperature. For the first problem with ethylene glycol, we can calculate the heat capacity by plugging in the given values: Q = (200 g)(1 cal/gC)(100C - 22C) = 15,600 cal. Then, we can use the formula c = Q/mΔT to find the specific heat capacity: c = (15,600 cal)/(200 g)(78C) = 0.995 cal/gC.
For the second problem with the metal and water, we can use the fact that the heat gained by the water is equal to the heat lost by the metal. This means that Qwater = Qmetal, so we can set up the equation (mwater)(cwater)(ΔTwater) = (mmetal)(cmetal)(ΔTmetal). We are given the mass and temperature changes for both substances, so we can solve for the heat gained by the water: Qwater = (15.8 g)(1 cal/gC)(1C) = 15.8 cal. This is also equal to the heat lost by the metal, so we can use the same formula as before to find the heat capacity of the metal: (15.8 cal)/(15.8 g)(1C) = 1 cal/gC.
In summary, to solve specific heat problems, we need to use the formula Q = mcΔT and rearrange it as needed to solve for the specific heat capacity. It is also important to remember that the heat gained by one substance is equal to the heat lost by another substance, as seen in the second problem. I hope this helps with your lab report!
1. What is specific heat?
Specific heat is a physical property that measures the amount of heat energy required to raise the temperature of a substance by a certain amount. It is often represented by the symbol "C" and is measured in units of joules per gram per degree Celsius (J/g°C).
2. Why is specific heat important?
Specific heat is important because it helps us understand how different substances respond to changes in temperature. It also plays a crucial role in many real-world applications such as cooking, heating and cooling systems, and industrial processes.
3. How is specific heat calculated?
Specific heat is calculated by dividing the amount of heat energy (in joules) by the mass of the substance (in grams) and the change in temperature (in degrees Celsius). The formula is C = Q/mΔT, where C is specific heat, Q is heat energy, m is mass, and ΔT is the change in temperature.
4. What factors affect specific heat?
The specific heat of a substance can be affected by various factors such as the type of substance, its state (solid, liquid, gas), and its temperature. Additionally, the atomic and molecular structure of a substance can also influence its specific heat.
5. How is specific heat used in real life?
Specific heat is used in a wide range of real-life applications, such as cooking and baking, designing heating and cooling systems, and in industrial processes like metallurgy and chemical reactions. It is also an important factor in understanding the Earth's climate and weather patterns.
  • Thermodynamics
