Static friction and centripetal force
The discussion focuses on determining the maximum angular velocity of a block on a turntable without slipping, given the coefficient of static friction (\mu_s) and the radius (r). The relevant equations include the static friction force and the centripetal force, leading to the relationship that the static friction force equals the centripetal force for equilibrium. The solution derived is \omega = \sqrt{{\mu_s g}/{r}}, which seems to be confirmed as correct by participants. The problem is being used as a reference to clarify misunderstandings related to another question. The final expression for angular velocity appears satisfactory to the contributors.
Xamien
"If the coefficient of static friction between the block of mass m and the turntable is \mu_s, determine the maximum constant angular velocity of the platform without causing the block to slip." I'm actually using this problem to understand why I'm getting the wrong answer to another question, unfortunately the book doesn't actually say if I have the right answer to THIS one. r is the radius, of course.
f = \mu_s F_{n}\<br /> <br /> F = m r \omega^2 \<br /> <br /> \sum F = F_1 + F_2<br /> <br /> F_{n} = m g
Using summation, I set the static friction force equal to the centripetal force for equilibrium and solved for \omega.
That final expression looks OK.
Thanks!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
