System of 2 Equations: Homework Statement and Attempt Solution
akaliuseheal
[/B]
It's a system of 2 equations.
My attempt is not worth writing here.
Results I got using Microsoft Mathematics without showing me step by step.
akaliuseheal said:
[/B]
Your attempt is worth it! It shows us you made effort to solve the question.
You have that ##y## must be equal to both ##\frac{1}{750} + \frac{8}{x}## and ##\frac{3}{2500} + \frac{12}{x}##
Thus you need to solve for ##x##: ##\frac{1}{750} + \frac{8}{x} = \frac{3}{2500} + \frac{12}{x}## and then substitute your answer for ##x## to obtain the value for ##y##
The most straight-forward way to solve a system of equations (although not always the most efficient way) is:
  • Use the first equation to solve for one variable in terms of the rest
  • In the second equation, replace that variable by its value (found in step 1). This will give you an equation involving one fewer variable.
  • Now, solve for a second variable.
  • Continue for as many equations as you have (which should be the same as the number of variables)
In your case, the first equation already gives you y as a function of x. So just use that value of y in the second equation, and see what you get.
Okay, so I did manage to solve it. I was stuck for some time on fractions. Thanks
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
