Building a Robot Like Tars from Interstellar
Building a walking robot similar to TARS from "Interstellar" poses challenges due to the complexity of its movement mechanisms, which are primarily CGI. Beginners are advised to start with simpler robotics projects to gain foundational knowledge in mechanics, such as pulleys and levers. Resources like online courses or beginner robotics kits, such as LEGO Technic or Meccano, can provide essential hands-on experience. Experimenting with basic frames and movement concepts is crucial before attempting advanced designs. Gaining a solid understanding of robotics principles will be necessary for successfully replicating TARS-like movement.
mohamed khairy
well , i want to build a very simple walking robot . but i would like to have a special walking mechanism . i'd like it to be like Tars robot in interstellar movie . this video shows the movement mechanism of it . the problem i can't figure out how to build such mechanism of movement . any help will be more than appreciated
motors, levers and a shifting center of mass.
It seems simple enough to discover by experiment.
You can build the basic frame out of lego or mechano or just blocks of wood to see where you have to shift things about - start by getting it to move like a man on crutches, then work out the other modes:
http://interstellarfilm.wikia.com/wiki/Robot
A problem with trying to reproduce the motion of machines found in movies is that objects like the Tars robot are CGI and puppetry - i.e. not subject to the same constraints. You are unlikely to get it exactly the same.
The kind of thing you are attempting, though it seems simple, is actually the subject of postgrad research in robotics.
http://www.gizmag.com/ranger-walking-robot-world-record/15826/
well , i really appreciate you concern simon bridge . but would you please be more specific or even give a resource i can search in as I am nope in this field . i even don't know how pulleys , levers and motors work . so if there is any online course or a textbook describing such stuff please tell me ...
Thanks in advance
Thanks in advance
Welcome to the PF.
Since you are just starting out in robotics, perhaps consider starting with a simpler project. I did a Google Images search on Beginner Robotics Projects, and got a lot of interesting looking hits. See if any of these look like they would be fun to start out with:
https://www.google.com/search?aq=&r...source=og&sa=N&tab=wi&ei=FGX_VKzdDpTdoATQ9YF4
http://content.vexrobotics.com/images/products/overview/ClawbotStarterKit_374x200.jpeg
:smile:
Likes Simon Bridge
... an advanced project like TARS will require, at least, that knowledge. I'll recommend the same as berkeman. Possibly even get starter engineering project kits like lego technik or mechano.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
