The equivalent resistance for the resistors in this circuit?
The discussion revolves around calculating the equivalent resistance of a circuit with both series and parallel resistors. The user initially calculates R1 as 20 ohms and R2 as 10 ohms, with R3 being 9 ohms, and attempts to find the equivalent resistance using R1, R2, and R3 in parallel. There is uncertainty about the interpretation of the parallel notation (//) and the potential difference across the resistors. Suggestions include using voltage and current equations to analyze the circuit and considering potential dividers and symmetry for simplification. The conversation emphasizes the need for clarity in circuit connections and calculations.
Islam Sabry
If the circuit of parallel and series resistors , is as follows , what's the equivalent resistance for the group?
neglecting the battery internal resistance... irrelevant to the question.
I tried to do the following
R1=8+12=20 ohms
R2=4+6=10 ohms
R3=9 ohms
then,
R(equivalent)= R1//R2//R3
but I'm not sure!
Ω
R1=8+12=20 ohms
R2=4+6=10 ohms
R3=9 ohms
then,
but I'm not sure!
I am not sure how the double slashes in R1//R2//R3 are interpreted mathematically. Can you imagine what the potential difference across the 9 Ω resistor might be?
Likes CWatters
means that R1 , R2, and R3 are connected in parallel ... and the question contains no voltage value..sorry if it's vague.
Islam Sabry said:
R1=8+12=20 ohms
True, but not useful since the current is not flowing through these two in turn.
Create unknowns for all the voltages and currents, write down all the equations, and solve.
Likes Islam Sabry
For this circuit there is an easy way to solve it. Take a look at the resistor values and think about potential dividers and symmetry.
Likes Islam Sabry and gneill
R1=8+12=20 ohms
R2=4+6=10 ohms
R3=9 ohms
then,
but I'm not sure!
Denote the nodes where the 9 Ω resistor is connected as X and Y.
Now imagine the circuit with the 9 Ω resistor temporarily removed. With the 9 Ω resistor gone, write expressions for the voltage at X and the voltage at Y.
Likes Islam Sabry
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
