The symbol t in the capacitor discharge formula q= (q0e)^(–t/RC)
The symbol t in the capacitor discharge formula q = q0e^(-t/RC) represents clock time, starting at t=0 when the capacitor begins discharging. The time constant τ, defined as τ = RC, is crucial for understanding the discharge process, as it has dimensions of time. The equation can be rewritten as q(t) = q0e^(-t/τ) to incorporate this time constant. Each time constant τ results in the charge decreasing to approximately 37% of its initial value. This understanding aids in visualizing the exponential decay of charge in capacitors over time.
hidemi
In the capacitor discharge formula q= (q0e)^(–t/RC) the symbol t represents:
A)the time constant
B)the time it takes for C to lose the fraction 1/e of its initial charge
C)the time it takes for C to lose the fraction (1 – 1/e) of its initial charge
D)the time it takes for C to lose essentially all of its initial charge
E)none of the above
The answer is E.
q= (q0e)^(–t/RC)
If none of the above is correct, what is a good definition of the symbol t (time)?
Clock time. It's the same ##t## as in ##x=v_0t+\frac{1}{2}at^2##. Here the imaginary clock starts ticking at ##t=0## when the capacitor starts discharging.
Likes rsk and hidemi
Ok I see.
Another question is that why we need to divide the time by the time constant (tao)?
hidemi said:
Ok I see.
As you know, the charge on the capacitor at any time ##t## is given by ##q(t)=q_0e^{-\frac{t}{RC}}.## The product ##RC## has dimensions of time. So we define time constant ##\tau=RC## and substitute in the equation to get ##q(t)=q_0e^{-\frac{t}{\tau}}.##
Ok I see. Thank you.
Likes berkeman and kuruman
Another helpful mental picture is to understand that for each time constant ##\tau## the level of charge goes down to ##\frac{1}{e}## of its initial level Q. That is about 37% left after each time constant. So after one time constant Q goes to Q*0.37Q, after 2 time constants, Q has gone down to Q*(0.37)^2, and so on.
https://www.eecs.tufts.edu/~dsculley/tutorial/rc/dischargeCurve.jpg
Likes hidemi and Delta2
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
