What is the Difference Between Color Temperature and Actual Temperature?
  • Thread starter Thread starter christian0710
    Light Temperature
Color temperature, such as the 1850K of candlelight, refers to the perceived color of light emitted rather than the actual thermal temperature of the object. Candlelight's yellow hue is primarily due to carbon emissions, which can mimic the appearance of a higher temperature black body. Non-black body radiation, like that from candles or fluorescent lights, results from specific emission lines rather than continuous thermal radiation. The energy of photons emitted from both black bodies and non-black bodies can be similar, but their origins differ; black body photons arise from thermal excitation, while candle photons result from exothermic chemical reactions. Understanding the distinction between temperature and heat is crucial, as the energy emitted by light sources does not directly correlate with their thermal properties.
christian0710
Hi, I'm learning photography and I learned that the color temperature of Candle light is about 1850K. However if the temperature of a candle light was 1850K I think it would burn you up, so my question is. What is the difference between Color temperature and temperature of an object? why does the candle light give off a color temperature of 1850K if it's not its real temperature?
I know this: The color temperature is the color a black body would give off at a specific temperature, but how come other objects than black bodies (candle light, floureescent light etc.) can give off those colors at much lower light?
Science news on Phys.org
Non-black body radiation is dominated by specific emission lines. The yellow color of candle light is mainly caused by carbon. The resulting impression of the flame color corresponds to the emission of a black body with a higher temperature.
Does that mean that the color we see from non black-body objects is not a color that originates from that objects temperature but rather from the photons of light that the electrons give off when non-black bodie's atoms interact in chemical reactions?
How do these photons differ from the photons given off by a black body if the color is the same? Are they the same photons with the same amount of energy?
Wait i have an idea: If you have red color from a candle and red color from a black body, both photons have the same energy level. The photon from the candle got it's energy from the exotermic reaction, while the black body photon got it's energy by heating the atoms up. In both cases the electrons jumped between quantum levels such that the difference in energy emitted is the same?
I doubt that the spectrum from a candle flame is very different from black body. After all, what you are seeing is the light radiated from lots of little black bodies (the carbon particles).
But when you are talking about "colour" you are referring to the subjective effect of the spectrum of the light reaching a human eye. The tristimulus theory of colour vision tells us that you can give a very good match for any particular colour with a suitably weighted sum of any three or more Primaries. This is the basis of Colour TV.
But, back to the OP. Watching the spectrum of the light emitted from a candle does not involve getting close enough to burn yourself. The actual energy per unit area of your body is minuscule and that is what counts when considering how 'hot' it will feel. They are two totally different concepts - consider the Sun.
You are confusing temperature with heat. You can stick your hand in a hot oven without burning it, but boiling water (at a lower temperature) will cause severe burns. That's because the air in the oven has a high temperature, but doesn't carry much heat. It's the same with light.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
