Calculating Mass of Melting Ice in a Copper Rod | Introductory Physics Homework
The discussion revolves around calculating the mass of ice melting per second in a copper rod heated at one end and cooled at the other. The user correctly identifies that the heat transfer equation involves the thermal conductivity of copper, the cross-sectional area, and the temperature difference, which is assumed to be 100 degrees Celsius. They derive a heat flow of 10.4 J/s and relate it to the latent heat required to melt ice, leading to a mass flow rate of approximately 3.1045 x 10^-5 kg/s. Clarifications on the time factor in their calculations confirm that their setup is correct, and it takes about 32 seconds to melt 1 gram of ice. The user expresses gratitude for the assistance in confirming their logic.
2099
Hello,
This is a homework problem for my Introductory Physics(no calculus) class but it's relatively simple so I opted to put it under high school. First I'll state the problem then my thoughts.
A copper rod (k = 390) has a length of 1.5 m and a cross-sectional area of 4.00*10^-4 m^2. One end of the rod is in contact with boiling water and the other with a mixture of water and ice. What is the mass of ice per second that melts? Assume that no heat is lost through the side surface of the rod.
This seems simple enough. Obviously
Q=(390*(4*10^-4)*DT*t)/1.5
DT is where I am coming across a problem. Am I supposed to assume that it is 100-0? Doing so gives
Q=10.4*t J*s
My idea is that in order for the ice to melt it has to have at least m*L (L=33.5*10^4) so I set 10.4*t=m*L
and it follows m/t=10.4/(33.5*10^-4) which is approximately 3.1045*10^-5 kg/s
I would greatly appreciate it if any could help me with this. I can't seem to find much information on this type of problem and I've looked to other books. They seem to have this problem, but no solution.
Anyway, I'm not looking for an answer just trying to see if my logic is correct. Thank you in advance
Q=10.4*t J*s
Since the question asks for the rate of ice mass melting/second, you are interested in finding Q/t. This is proportional to the thermal conductivity, area and temperature difference and inversely proportional to the length of the conducting body (rod). You have to use the entire temperature difference, which is 100 degrees. That gives you Q/t of 10.4 J/sec. as you have found, which looks correct.
As you seem to realize, you have to figure out how much heat flow is required to melt one gram or kg. of ice per second. The latent heat of water is 334 kJ./kg. or 334 J/g.
The rest is just plugging in the numbers.
AM
Thank you for your reply. I understand what you are saying I just can't tell if I've set it up correctly or not. There is 10.4 J/s or W going to the mixture, I know it takes 33.5*10^4 J to melt 1 kg of ice, but it is the time factor that is confusing me. Is this Q/t=(mL)/t okay, because if I don't put the time on the other side I get something like kg = kg/s
Anyway, I still come up with 3.1045*10^-5 kg/s approximately.
That looks right. It takes about 32 seconds to melt 1 gram.
AM
Alright, thank you again.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
