Thermal Expansion of a drinking glass
The discussion centers on calculating the amount of water that spills from a drinking glass due to thermal expansion when the water temperature rises from 2.0°C to 34.0°C. The coefficient of thermal expansion for water is given as B=207*10^-6. The initial calculation resulted in a spill of 1.77mL, while the textbook states the answer is 1.66mL, prompting questions about potential errors in the calculation. Participants suggest verifying whether the temperature increase is 32 degrees or if it is the final temperature of 32 degrees. Clarification on the temperature change is deemed necessary for accurate results.
mg1977
An ordinary drinking glass is filled to the brim with water(268.4mL) at 2.0C and placed on the sunny pool deck to enjoy. If the temp of the H2o rises 32.0C, how much water will spill out of the glass?Assuming no expansion for glass...
B=207*10^-6 for water, so: do I still include the coeff for glass?
So far I have: B(H20) * the difference of T *(if applicible)Vinital-a glass *the diff of T * Vinital
207*10^-6 *32.0 * 268.4mL = I end up with 1.77mL but the back of the book says 1.66mL What am I missing?
Did the temperature rise by 32 degrees or to 32 degrees? Double check this part of the question.
