Thermodynamics question regarding latent heat of fusion of ice.
The discussion revolves around calculating the total heat released by a copper container and water as they cool from 25.0 °C to 21.7 °C after adding ice. The correct heat released was determined to be 5154.104 J. The main challenge is calculating the latent heat of fusion of ice, which is given as 3.39 x 10^5 J/kg, but users are struggling to derive this value. The key equations involved are Q=mcΔT for temperature changes and Q=mL for phase changes, emphasizing the need to account for heat lost by both the copper and water. Properly applying these equations will lead to the correct calculation of the latent heat of fusion.
Bigdutchman
(a) An insulated copper container of mass 0.250 kg contains 0.350 kg water. Both the container and the water are initially at 25.0 0C. Then 0.012 kg of ice at 0.0 0C is added to the container. Eventually the container and contents reach thermal equilibrium at 21.7 0C.
(i) What is the total heat released (in J) by the copper container and the 0.350 kg water as they cool down from 25.0 0C to 21.7 0C?
I got 5154.104J (Correct answer)
(ii) Determine the latent heat of fusion of ice. <---- Can't do this mofo. Keep getting different answer. They have 3.39x10^5 J/kg. Can someone pls show me how they got that? THANKS!
Q=mc delta T
Q=mL
One of my failed attempts:
5154/0.012 = 4.29x10^5 J/kg
You are not taking into account the heat lost by the copper and the water.
AM
how do i do that? lol
If the copper changes temperature by \Delta T how much heat does it lose? Do the same for water.
AM
Q = mL for state changes. (mass, L being the heat needed, which is what you're trying to find)
and for heating of liquids, Q = mC * change in temp
heat lost by copper = -heat lost by water (i.e. heat is gained by water)
mC * change in temp for copper = - (mL + mC * change in temp for water)
rearrange to find L
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
