Thevenin equivalent with dependet sources
The discussion focuses on finding the Thevenin equivalent of a circuit with dependent sources. The original poster struggles with formulating the correct equations and seeks validation for their attempts. A suggestion is made to use nodal analysis to determine the output voltage (Vo) while considering the dependent source. The importance of expressing the results in a voltage divider format to extract the Thevenin voltage and resistance is emphasized. The conversation highlights the necessity of incorporating the dependent source into the analysis for accurate results.
elamre
Hello, i was studying diodes for my exam on monday, but i had some struggle finding the Thevenin equivalent. Here is the circuit:
http://img411.imageshack.us/img411/5336/schakeling.png
I have no clue what to put here?
I have made 2 equations with which i should be able to solve it (i think?) But i have no clue if I am doing it right! So can somebody check it?
ix = (5-Voc)/1000
and
ix - ix /2 = 5/1000
What is the motivation behind your second equation?
Well i tried to follow an example out of my book (electrical engineering fifth edition by allan r hambley) And i need my second equiation to solve the first equation. Its just that i can't think of 2 =/.
I see. Well, it doesn't look like a valid equation to me.
Here's a trick that often helps with these types of circuits. If you consider a general Thevenin source it's a voltage supply Vth with a series resistance Rth. When it's connected to some load resistance R, the two resistances will form a voltage divider for the Thevenin voltage source and the voltage across the load will thus be
Vo = V_{th} \frac{R}{R + R_{th}}
Now, if you stick a resistance R onto your circuit on the right as a load, you should be able to apply nodal analysis at the output node and solve for Vo. One equation! If you can then put the result in the form above you can read off both the Thevenin voltage and resistance directly.
Well i know that, but what about the dependent source? :)
Solve for Vo with the dependent source in place, of course. You'll be finding the expression for the current Ix through the 1000Ω resistor as part of the node equation analysis, so you can substitute for Ix/2 easily.
11K
