Thickness of 304 stainless sheet to avoid puncture
  • Thread starter Thread starter Nick P
    Thickness
The discussion focuses on determining the minimum thickness of a 304 stainless steel cylinder to prevent puncture from a 6-inch diameter steel bar dropped from a height of 1 meter. The cylinder's weight is approximately 5500 kg, with an outer diameter of 0.7512 meters. Calculations indicate that the force exerted on the cylinder is 3.66 MN, leading to a stress of 488 MPa, which is below the ultimate tensile strength of 517.02 MPa for stainless steel 304. The original poster expresses uncertainty about their calculations and suspects a logical error. Clarifying the thickness requirement is essential for ensuring structural integrity under impact.
Nick P
Designing a cylinder using Stainless Steel 304 and am trying to figure out the minimum thickness of the outer wall of the cylinder to avoid being puncture by a 6in diameter steel bar after falling 1 meter onto the bar.
Cylinder will weigh approximately 5500kg.
What is the outer diameter of the cylinder?
0.7512 meters
What I have right now... is that
Syp,SS304=206.8MPa
F=π(.075m)2*206.8E6 = 3.66MN
and relating that to the current thickness we have at 5cm
σ=\frac{3.66MN}{.15m*.05m}=488MPa
And 488MPa < Sut,SS304 with Sut,SS304=517.02MPa
But I'm pretty positive I'm making some logical error here.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
