Torque - Finding the unknown weight
  • Thread starter Thread starter ll Source ll
    Torque Weight
The discussion focuses on using torque to find the weight of an unknown object attached to a pole. A 10.0 m pole weighing 20.0 N has its center of gravity 2.00 m from one end, with the unknown weight hanging at the opposite end. The balancing point is 2.00 m from the unknown weight, leading to the equation Tcw = Tccw. By solving the torque equation, the unknown weight is determined to be 60.0 N. The user expresses gratitude for the assistance received in solving the problem.
ll Source ll
Torque is used to determine the weight of an object. A 10.0 m long pole weighing 20.0 N has its center of gravity 2.00 m from one end. An object of unknown weight is hung at the end opposite the center of gravity. With the object hanging at this end, the pole now balances 2.00 m from the unknown weight. What is the weight of the unknown weight? Ans:60.0
T = F * R
T = 20 * 2
= 40 ?
oh please anyone? my exams tommorow? I am sorry for being so naggy? any help AT ALL will be great. anything. I've been staring at this screen refreshing every 5 seconds.
PLeASE IM BeGGING YoUUUUUUUUUUUUUUUUUUUUUUUUUU
Ok let me have a crack at it.I assume that unknown object is at the other end of stick (not the center of gravity end). So
Tcw = Tccw
2*X = 6*20
X=60 N
Thank you so much. So, SO much. I love you. In a non-gay way. <3
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
