Trajectory of an electron traveling near a current-carrying wire
The discussion focuses on the trajectory of an electron traveling near a current-carrying wire, with initial values for magnetic field strength and force provided. The participant attempts to derive a formula that describes the electron's trajectory based on its distance from the wire (R), rather than time. They express that the vertical velocity remains constant while the x-component changes, leading to confusion about the relationship between velocity and time. A formula for force and acceleration is developed, but questions arise regarding the constancy of velocity as it is influenced by the magnetic field. The conversation highlights the complexities of calculating the trajectory and the need for clarity on how velocity varies in this context.
alesdiazdeo
There's an infinite vertical wire which produces 5Amps. An electron is 0.2 meters apart with a velocity of 10^5 m/s in the same direction of the wire. The wire is creating a magnetic field which alters the trajectory of the electron. I need to know to the function which represents it.
Fm(magnetic force)=q(v x B) (charge times vectorial multiplication of velocity and magnetic field)
Without vectors it's just Fm=qvB
B(magnetic field)=nu/2pi * I/R (I=current intensity, R=distance)
nu/2pi=2*10^-7 (it's a constant)
B equals 50*10^-7 T (at first instance)
Fm equals 8*10^-20 N (at first instance)
I know Fm is perpendicular to the velocity, and I know the estimation of the trajectory (somewhat similar to the curve y=lnx).
Since I think vertical velocity will be constant, only changing the x component, I tried summing the Fm and the B formula, creating a bigger formula which I think represents the growth on the Y axis of the final desired formula dependent to R. That's what I want, not a formula that depends on time but a formula that depends of the distance to the wire (R).
What is the quantity your formula should compute?
I would describe the trajectory of the electron with an x and y coordinate, where:
x is the distance to the wire
y = the distance the electron has traveled since the start of the experiment. obviously (y = vt)
x will depend on t, an easy computation with Newton's second law (F = ma)
Using y = vt, you can also make x dependent on y.
There are no preferences, just calculation of the trajectory is my task.
Alright, so I inserted the B formula into the Fm formula and got Fm=1.6*10^-20/R.
Divided it by the mass of the electron and got the acceleration.
Did the integral of that and got v=1,76*10^10*ln|R|+C (which I assume is 0 since R=inf -> v=0)
I thought that was a good representation of the Y axis and the X axis could be represented by 10^5 (constant) but my friend tells me that v (on the X axis) also changes with time.
So I'm lost again.
What makes you think that ?
That the initial statement was that; but of course v is only constant in module, not as a vector, as it varies with F=qvB.
