Trickey projectile motion question
The discussion centers on solving a projectile motion problem involving a shell fired from a cliff. The first part requires demonstrating that the maximum horizontal distance traveled by the shell is given by the formula (U/g)(U^2 + 2gh)^(1/2). The second part involves finding the angle for maximum distance, expressed as tan^(-1){U/((U^2 + 2gh)^(1/2))}. Key considerations include the separation of horizontal and vertical motion components and the influence of the cliff's height on travel time. The use of trigonometric substitutions is suggested as a potential method for solving the problem.
kilianod
trickey projectile motion question!
1. (i)A shell is fired with speed 'U' from a point on a cliff of height 'h' above sea level. Show that the greatest horizontal distance that the shell can travel before reaching the sea is
(ii)and that the angle for maximum distance is
also given in the question is a general projectile equation
y= (x)(tan(a) - {(g)(x^2)}/{(2)(U^2)((cos(a))^2)}
Ive repeatedly attempted this with little success, i think the key is use of trigonometric substitutions, but I am not sure. Please Help!
Well for the first part I assume the projectile is fired horizontally. The maximum distance it can travel depends on its travel time. The travel time all depends on the height of the cliff. With these questions you need to consider horizontal and vertical components separately.
Thread 'Minimum mass of a block'
Here we know that if block B is going to move up or just be at the verge of moving up ##Mg \sin \theta ## will act downwards and maximum static friction will act downwards ## \mu Mg \cos \theta ## Now what im confused by is how will we know " how quickly" block B reaches its maximum static friction value without any numbers, the suggested solution says that when block A is at its maximum extension, then block B will start to move up but with a certain set of values couldn't block A reach...
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
