Tricky Exponential/Logarithmic Indefinite Integrals
Liquid7800
Hi,
Our professor has only taught us these methods for Integration...thus far:
Direct Integration
Substituion Method
So theoretically we should be able to solve these problems by substitution, direct integration...(double substitution) & by algebraic manipulation etc.
Ive attached 3 attempts at answers for 3 problems:
This first problem I am curious how our professor got "the answer in question"...Ive tried my best but all I could get was "my answer" the logic seems correct...see image
This second problem I am curious why our professor also gave "the answer in question"...Ive tried my best but I would like to know if I am solving this correctly "my answer"...see image
This last problem I am just curious to see if this is the correct way to solve this problem "my answer"...see image
Your difficulty appears to be bad algebra. In the first problem you have
\frac{2e^{2x}- 8/3}{2e^{2x}- 5}
and cancel the "2e^{2x}" terms. You can't do that.
In the second problem you have, in one equation,
\frac{1}{\sqrt{2+ u^3}}[/itex]<br /> and in the next, the square root has magically disappeared!<br /> <br /> In the third problem, you have <br /> \frac{1}{2}\int 9^{u^2} du<br /> and somehow that becomes <br /> \frac{1}{2}\int log_9(u)du[/itex]&lt;br /&gt; How did the exponential become a logarithm?
Thanks for the reply and suggestions...
Ive since gotten the answers to problems #1(didnt balance the algebra correctly) and #3 (used the wrong integral formula)..
However, I believe #2 is correct...perhaps my posted image is bad...I don't have the equation
<br /> \frac{1}{\sqrt{2+ u^3}}<br />
anywhere...or at least I shouldn't!
In #2 after you do the substitution you have 1/sqrt(1+u^2). But the integration formula you apply is for 1/(a^2+u^2) (without the square root). You need an integration formula for 1/sqrt(u^2+a^2).
In problem 2, the obvious and natural method to evaluate \int\frac{1}{\sqrt{1+u^2}}\,du is trig substitution. Unfortunately, you said you are not allowed to use that method.
You could use the completely unmotivated trick of multiplying numerator and denominator by u+\sqrt{1+u^2}. Then the substitution w=u+\sqrt{1+u^2} works.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
