Try it do you get the same answer?
  • Thread starter Thread starter aisha
aisha
6\cos^2(\theta)+\cos (\theta) -1=0
I solved this equation and got \theta= 71 degrees, 289 degrees, 240 degrees, 120 degrees. :rolleyes:
Yes, I got the same answers.
anyone else want to give it a try?
Yes! Your answers are correct. :biggrin:
