Two blocks and a pulley homework
The discussion centers on a physics homework problem involving two blocks connected by a string over a frictionless pulley. The 3 kg block experiences kinetic friction with a coefficient of 0.1 on a horizontal surface, while the 7 kg block falls under gravity (9.8 m/s²). The spring constant is 5 N/m, and the task is to calculate the distance 'h' the 7 kg block falls before stopping, as well as the kinetic energy of both blocks after the 7 kg block descends 10.5056 m. Key equations involve energy conservation and the work done by friction.
  • Understanding of Newton's laws of motion
  • Knowledge of energy conservation principles in mechanics
  • Familiarity with spring mechanics and Hooke's Law
  • Basic concepts of kinetic friction and its calculations
  • Calculate the distance 'h' using the formula h=2(m-uM)g/k
  • Analyze the energy conservation equation: E=mgh and its components
  • Determine the total kinetic energy at a specific distance using KE equations
  • Explore the effects of varying the coefficient of friction on the system's dynamics
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of pulley systems and friction in practical applications.
duketogo
The two blocks are connected by a light string that passes over a frictionless pulley with a negligible mass. The 3 kg block lies
on a rough horizontal surface with a constant coefficient of kinetic friction 0.1. This block
is connected to a spring with spring constant 5 N/m. The second block has a mass of 7 kg.
The system is released from rest when the
spring is unstretched, and the 7 kg block falls
a distance h before it reaches the lowest point. acceleration of gravity is 9.8m/s/s
Calculate the falling distance h where the
7 kg blocks stops. Answer in units of m.
Note: When the 7 kg block is at the lowest point velocity is zero
and then
calculate the moment when the 7kg block has descended by a distance of 10.5056m, where 10.5056 is less than h. at this moment calc the sum of kinetic energy for the two blocks in joules.
E=mgh= M m work
(1/2mv^+1/2kx) + (1/2mv^2+ mg(h-x) + (f sub k * x)
this equaition was given by a friend but I can't seem to make it work
h=2(m-uM)g/k
any help on setting up the problem would be appreciated
for the second part here's what I got thus far total k.e.= 1/2mv^2 +1/2Mv^2= mgx - 1/2kx^2-uMgx
but I'm not sure about it.
there's a picture of the diagram here
duketogo said:
E=mgh= M m work
h=2(m-uM)g/k
The basic idea is energy conservation:
Mechanical Energy(initial) + Work done by friction = Mechanical Energy(final)
Mechanical energy is the sum of spring PE (½kx²), gravitational PE, and KE.
Work done by friction (which is negative) = -μNx
okay I'll try it out
  • · Replies 20 ·
