Two Masses, a Pulley, and an Inclined Plane help
The discussion focuses on solving the problem of two connected masses over a frictionless pulley, with one mass on an inclined plane experiencing kinetic friction. The equations of motion for both masses are established, leading to the expression for the mass ratio m1/m2. A key point raised is that a term was omitted in the initial solution, specifically the acceleration 'a' in the numerator. The correct ratio is derived as m1/m2 = (gsin(theta) + mu gcos(theta) + a) / (g - a). The conversation emphasizes the importance of including all relevant terms in the equations to arrive at the correct solution.
pcmarine
Block 1, of mass m1, is connected over an ideal (massless and frictionless) pulley to block 2, of mass m2, as shown. Assume that the blocks accelerate as shown with an acceleration of magnitude a and that the coefficient of kinetic friction between block 2 and the plane is mu.
Find the ratio of the masses m1/m2.
:confused:
Let the tension in the thread be T. ok. now eq of motion of the 2 masses are...
(m1)g - T = (m1)a
T - (m2)gsin(theta) - (mu)(m2)gcos(theta) = (m2)a
Solving them by addng the two eqns u get,
m1/m2 = (g(sin(theta) + (mu)cos(theta)))/(g - a)
Thanks rammstein, but after inputting m1/m2, I get "aren't you missing a term?" Thanks a bunch for the help though!
That's right. The equations of motion are correct, he just dropped a term when he solved for m1/m2. Go ahead and solve the system and see what you get.
-Dan
I tried setting the two equations equal to each other through T, but was unable to discover the missing term...
m_1g-T=m_1a So T=m_1g-m_1a
(m_1g-m_1a)-m_2gsin \theta-\mu m_2gcos \theta=m_2a
m_1g-m_1a=m_2gsin \theta+\mu m_2gcos \theta+m_2a
m_1(g-a)=m_2(gsin \theta+\mu gcos \theta+a)
\frac{m1}{m2}=\frac{gsin \theta+\mu gcos \theta+a}{g-a}
rammstein left out the last "a" in the numerator.
-Dan
Likes Qexyario
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
