Are You on the Right Track with Separation of Variables for PDEs?
Kidphysics
This is the first problem of the two.
Using separation of variables, I end up with
T'(t)= -λKT(t) and X''(x)+(β/K)X'(x)/X(x)= -λ. At first I chose the negative lambda because I saw that U(0,t) and U(L,t) needed to oscillate and I was hoping to get a sin function. Now the characteristic equation for X is something like r^2 + (β/K)r +λ=0 and I am not sure if I am on the right track in solving for the function X(x).
You're on the right path, but it helps to use 2 instead of λ.
thanks. I guess what I should have said is that I am stuck at this point.
Solve the characteristic equation for r. The solution has the form C1Exp(rx)+C2Exp(-rx).
This might become D1sin(r'x)+D2cos(r'x) depending on the sizes of β, k, and λ.
Edit:If r was imaginary, r' is a new constant that is real.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
