Uncovering the Mystery of Work Done by Conservative Forces
Work done by conservative forces is defined as Wc = -ΔU, where ΔU represents the change in potential energy. In the discussed scenario, a block sliding on a flat table experiences friction, which is a non-conservative force, leading to work done that does not result in a change in potential energy. The confusion arose from mistakenly considering friction as a conservative force, which it is not, as it depends on the path taken. Therefore, in the absence of potential energy changes, no work is done by conservative forces. Understanding the distinction between conservative and non-conservative forces clarifies the application of the work-energy principle.
ikjadoon
Work done by conservative forces = -\DeltaU
Above.
Here is the whole equation:
Wc+ Wnc = \DeltaK.
Wnc = \DeltaK + \DeltaU.
So, Wc = -\DeltaU.
But, for example, how does that apply in a situation with no potential energy changes, but still with work done by conservative forces?!
Example: a block slides across a horizontal, flat table and comes to rest due to friction. There was no change in gravitational or spring-related potential energy (the only two forms of potential energy I can think of). However, there was work done (50J or whatever) by friction on the block. Thus, 50J = 0J! There is no change in potential energy, but there was work done by conservative forces.
Where did I go wrong?
Thanks,
~Ibrahim~
Why did you assume that friction was a conservative force? either one of your first 2 equations would be OK to use. The third one says that since there was no potential energy change, there was no work done by conservative forces (no work done by gravity, springs, or other conservative forces).
Oh, crap.
Friction is a non-conservative force: it depends on the path.
There are no conservative forces acting, only non-conservative (friction).
0J = 0J.
Got it. Thanks for the solution, however simple!
~Ibrahim~
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
