Understanding Index Notation in Engineering and Physics
Index notation is crucial for expressing vector equations in engineering and physics, particularly when dealing with forces and components. The discussion revolves around converting force equations and components into index notation, specifically for gravitational force and normal components on surfaces. Participants clarify the representation of vectors and components, with emphasis on using the metric tensor in calculations. The conversation also touches on the relationship between the metric tensor and matrix representation, highlighting the need for a solid understanding of these concepts. Mastery of index notation is essential for accurately solving problems in engineering contexts.
chusifer
hello, i just started learning index notation in my engineering class, and I am having some trouble. one of the problems on my homework was:
putting this in index notation:
\vec{f}=g \frac{m_1m_2}{\vec{r}^2} \ \frac{\vec{r}}{\sqrt{\vec{r}^2}}
and then another problem that reads...
consider a plane with outer normal vector v_i on which a force is acting f_i. what are the normal components of force on the surface? wut is the max shear component? what direction is the max shear component pointing? write this in index notation.
i can figure out the components...just not how to write them in index notation. so any help here would be appreciated. thanks
For your f, you may write:
f_{i}=\frac{Gm_{1}m_{2}}{r_{j}^{2}}\frac{r_{i}}{\sqrt{r_{k}^{2}}}
I read "g" as "G" ; hope I was right about that..:wink:
f^a=g \frac{m_1m_2}{(r_b r^b)^{3/2}} \ r^a
Given a vector \vec f and a unit-vector \hat n,
the vector component of \vec f along \hat n is
(\vec f\cdot \hat n)\hat n.
In index notation,
( f^a g_{ab} n^b) n^c, where g_{ab} is the Euclidean metric tensor and n^a g_{ab} n^b=1.
for the problem with the normal vector and external force, arent the components fsin and fcos? how would i turn those into index notation?
f^a g_{ab} n^b=\vec f\cdot\hat n =|\vec f | |\hat n|\cos\theta _\text{between f and n }=|\vec f | \cos\theta _\text{between f and n }
hmmmm g_a_b ...that sounds like the matrix B_i_j my prof was talking about. I am unfamiliar with the term Euclidian metric tensor...but am i right in calling it a matrix?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
