Understanding the Role of c1c2 and 2b in the Energy in Accident Equation
  • Thread starter Thread starter Probie
    Accident Energy
The discussion focuses on clarifying the mathematical interpretation of terms in the equation E = L * ((a / 2) * (c1 + c2) + b / 6 * (c1² + c1c2 + c2²) + (a² / 2b). Participants confirm that "c1c2" means c1 multiplied by c2, and "2b" indicates 2 times b. After understanding these terms, the original poster recalculates the equation and arrives at E = 1726.66675. The conversation emphasizes the importance of correctly interpreting mathematical notation for accurate calculations. Overall, the clarification significantly improved the user's understanding and results.
Probie
Can someone please tell me what I am suppose to do with c1c2 and 2b in the following equation. I do not know if I am to mulitply, divide, subtract or add.
E= L * (( a /2 ) * ( c1 + c2) + b / 6 * ( c1² + c1c2 + c2² ) + ( a² / 2b))
Where: L = 1
a=375
b=45
c1=.33
c2=.33
My answer comes out to 62.205 but I do not know if this is right because I do not know what this c1c2 and 2b means.
Thanks very much.
c1c2 means c1 multiplied by c2. 2b means 2 multiplied by b. Is that what you were after?
Yes, that is exactly what I needed to know. It sure made a difference in my answer...now I come up with E = 1726.66675 I sure do hope this is right. I am not a student and there is no way to check my findings.
Cristo...thanks very much for the prompt reply, this is very important to me...thank you.
You're welcome. In general, whenever you see a combination "ab", it always means a multiplied by b; that is, for this sort of maths, the multiplication operator is the only one to be omitted in this way.
Thanks again cristo...this is a lesson I will never forget...thank you very much. ~ Probie
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
