How Strong is the Electric Field Between Two Plates?
The electric field strength between two plates separated by 1.2 cm with a potential difference of 25,000V is calculated using the formula E=V/D. Substituting the values, E equals 25,000V divided by 0.012m, resulting in an electric field of approximately 2,083,333.3 V/M. The calculation confirms that the problem has been correctly solved. There is no issue with the answer, as it has been verified. The discussion concludes with reassurance that the calculation is accurate.
Kajayacht
1. If the accelerating plates are 1.2cm apart and have a potential difference of 25,000V what is the magnitude of the electric field between them?
2. E=V/D
3. E=25,000V/1.2x10^-2m= 2083333.3 V/M
So, what's the problem? It seems to me that you've already solved it.
I didn't know if I got the question right...
You did. I checked it on my calculator.
