Why Does Unpolarized Light Lose Half Its Intensity Through a Polaroid?
Unpolarized light loses half its intensity when passing through a Polaroid due to the equal likelihood of light components aligning with the filter direction or being perpendicular to it. This results in a factor of 0.5 for the transmitted intensity. The angle of 30 degrees between the first filter (12 o'clock) and the second filter (1 o'clock) is derived from the geometric positioning of these angles, with 1 o'clock being one-third of the way from 12 to 3 o'clock, which is 90 degrees. The intensity of the light after passing through both filters can be calculated using the equation I = I0 * 0.5 * cos²(30). Understanding these principles helps clarify the behavior of light through polarizing filters.
superslow991
Unpolarized light of intensity Io passed through a Polaroid sheet with its polarizing axis at the 12 o'clock position and then through a second with its polarizing axis at the 1 o'clock position. What is the intensity of the emerging light?
[/B]
I= I0 *0.5*cos2(30)
Now i know the solution i just want a break down of the question. Why is it that when a unpolarized light passed through a polaroid, it loses 1/2 its intensity?
Also where would the 30 degrees come from? Also is it possible to draw this question out?
Intuitively, the factor of 0.5 is because the unpolarized light is exactly as likely to have components aligned with the filter direction as at right angles. So half the light intensity gets through. You can probably do a little trig and calculus to calculate the 0.5. The cos(30) is due to the angle between the first filter at 12 o'clock and the second filter at 1 o'clock.
Likes superslow991
Hmm how can you be sure that the angle between the 12 o clock filter and 1 o clock filter is 30 degrees though?
12 o'clock is straight up and 3 o'clock is horizontal so that is 90°. So 1 o'clock is 1/3 * 90° = 30°
Likes superslow991
ok thanks a lot
